techc0de's avatar
techc0de
Disable auto update on Orbi RBK50 ?
Hello all,
I had read many threads and tried out several methods suggested by the community to disable the auto update on my Orbi RBK50.
The currently firmware is v2.7.3.22, and I tried rolled it back to v2.7.2.104.
It worked but then the router auto update the firmware itself to a newer version the next day.
I want to stay on v2.7.2.104 for the Telnet feature.
Here the commands that I used:
nvram set orbi_auto_upgrade=0
nvram set auto_check_for_upgrade=0
nvram set auto_update=0
nvram set orbi_auto_upg=0
nvram set orbi_auto_flag=0
nvram set telnetd_enable=1
nvram commit
Any suggestion is helpful.
Thanks
  • FURRYe38's avatar
    Install a upstream router for firewall device in front of the RBR and block services there...
    • techc0de's avatar
      techc0de
      My current setup is using an AT&T Modem/Router unit as a passthrough for the Orbi router.
      • FURRYe38's avatar
        Add the following key words to the ATT router:
        http.fw.updates1.netgear.com
        I believe you'll need to remove IP-pass thru to make this work...
        You should see "Service Not Reachable" on the RBRs FW update check page if it works.
  • I scanned some domains' netgear.
    http.fw.updates1.netgear.com,
    time-e.netgear.com,
    e70.g.akamaiedge.net,
    www.netgear.com,
    netgear.com,
    devcom.up.netgear.com,
    registration.ngxcld.com,
    netgear-devrecog.fing.io
    If you use pfsense, you will create alias and create rules on WAN tab then block Router & Satellite IP access Alias. See picture below.
    • FURRYe38's avatar
      Only ones needed are:
      • 100won's avatar
        100won
        Star
        Hi,
        I tried to block 2 domains but failed.
        So that I scanned some domains which the router and satellite access.
        When you go to Advanced - Administration - Firmware Update. The router will access to devcom.up.netgear.com, a1599er83nvyl8.iot.us-west-2.amazonaws.com, www.netgear.com
        When using NG's ntp server, it will connect to time-e.netgear.com
        The "cached" domain a1599er83nvyl8.iot.us-west-2.amazonaws.com can change anytime they want. That is the reason I list some domains.
        If we use pfsense, we can block only .*netgear.com, .*ngxcld.com for all subdomains. And e70.g.akamaiedge.net
        I tried to update voxel's firmware, the router access to this domain: netgear-devrecog.fing.io
