Orbi WiFi 7 RBE973
Reply
DoS Attacks in Logs
juniormint88
Tutor
DoS Attacks in Logs
Is it normal to see so many "DoS Attack: SYN/ACK Scan" in the router logs? I have AT&T GigaPower.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 4
Accepted Solutions
Re: DoS Attacks in Logs
well ether devices on your lan that have been torrenting or if you are on a dynamic ip address from your isp it could be who ever last had the ip address , its a pretty commoin thing to see in logs and is just identified wrong , if it does get worse prob time to get someone look into it and assess the security implications
Message 4 of 4
All Replies
generally these are just torrents that have been closed and peers are trying to still connect to your ip address
Message 2 of 4
juniormint88
Tutor
torrents in this case being devices connected to my router?
Message 3 of 4
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 7193 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
