Orbi WiFi 7 RBE973
Reply
Edit DHCP DNS servers - RBK50
jamesnahon
Initiate
Hi,
Is it possible to manually configure the DNS servers given out by DHCP by the RBK50?  I know you can change the DNS server for the route itself, I'm trying to configure the router to give out a DHCP lease with a DNS server other than itself.
Thanks
James
EDIT: i've searched the forums and there are lots of similar posts, but nothing conclusive from any recent posts.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Accepted Solutions
Guru
Re: Edit DHCP DNS servers - RBK50
Most NG routers including Orbi use a DNS proxy. Thus on the WAN side you can have the router use any custom DNS address. However for the LAN side, connected clients will always recieve the routers IP address for there DNS.
Message 2 of 4
All Replies
Guru
Message 2 of 4
jamesnahon
Initiate
That's sad to hear, but thanks for confirming.
Message 3 of 4
Guru
One thing about NG routers I wish NG would allow users to configure. Smiley Frustrated
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 7252 views
  • 7 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
