Orbi WiFi 7 RBE973
Reply
Factory reset but now can’t login to router ssid
RV078
I’m really hoping someone can help me.
I did a factory reset on my orbi, but cannot connect to the default SSID, as I no longer have the password that came with my system.
Tried to log into orbilogin.com but it won’t let me either.
Any ideas? Thanks so much in advance
Kumar
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 3
CrimpOn
Guru
Re: Factory reset but now can’t login to router ssid
When I did a factory reset yesterday on Orbi RBR50, I connected a web browser to 192.168.1.1 and it came up with the configuration screen.  The default user name is "admin" and the default password is "password".  One of the first screens asked me to enter a new password.  Of course, I did this from a Windows PC connected to an ethernet port.
When set to "factory", I believe the SSID and password are set to the ones printed on the label on the back.
Message 2 of 3
There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
See Labels.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2135 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
