Reply
Feature Request: Orbi Satellite Ethernet Backhaul
JMU1998
Luminary
Re: Feature Request: Orbi Satellite Ethernet Backhaul
Now even Amplifi are going to offer wired backhaul why does Netgear always have to play catchup after taking the lead? Competition always see to fly past Netgear even if Netgear starts ahead, just poor feature set and slow Firmware release plagues Netgear everytime they put out something promising, Orbi still has a lot of potential but features Must improve wired backhaul is one of them now every competitor is offering it!
Message 76 of 252
Hirrdgoon
Apprentice
Wait, how can Amplifi impliment wired backhaul with the wirless mesh Nodes? They don't have wired ports. Sure the router can do wired connections, thats not exactly what we mean by wired backhaul.
Or did they release new hardware?
Message 77 of 252
rafale7
Apprentice
It does sound odd on the Amplifi...
To feed on the discussion I actually have all 3 setups which was suggested to compare and ran a few tests.
I am in an environment where I have setup a single AP with 15 wireless clients on that AP. One is a IP cam streaming at 6Mbps all the others are a mix of 2.4GHz or on 5GHz AC or A/N. The mix is the same through the test. Using iperf 2 on a macbook pro (3x3 @5Ghz), all tested on the same channel and environment I have gotten the following results:
Apple Airport Extreme AC with the signal at -51dB varies from 520Mbps to 590Mbps
Ubiquity UAP AC Pro signal at -54dB varies from 350 to 400Mbps
Orbi single unit as an AP with signal at -49dB varies from 500 to 560Mbps
Pros and Cons:
Apple Pros: High speed in multi client environment, single interface. Rock solid stability and compatibility.
Apple Cons: Future support, no mesh, no dedicated wireless backhaul, no band steering/AP steering.
Ubiquity Pros: Controller interface offers a lot of options. Band steering, AP steering. Good stability
Ubiquity Cons: Relatively poor performance (coverage and speed). Verified on ubqt forum than cumulative bandwidth for 10 simultaneous clients is expected to drop to 300Mbps. I am observing 600Mbps+ on the old Airport. Best case peak single client is to reach 600Mbps (Vs 800+Mbps = gigabit  ethernet limit for Airport). No dedicated wireless backhaul (repeaters would have even worse performance). Has some compatibility issues with specific devices
Orbi Pros: High wireless speed and range. Dedicate backhaul meaning little/no performance degradation from satellite . Strong signal (though might not be good for speed).
Orbi Cons: No wired backhaul. Stability concerns from reports. Limited interface options.
Pretty disappointed overall by Ubiquity but there is hope in Orbi. I think having more than 2 wireless satellites per base may degrade performance of the satellites making the wired backhaul even more important for locations which have that option.
Message 78 of 252
st_shaw
Master
@rafale7 I'm curious. I don't have any 3x3 AC devices to test with, so I can't max out my Ubiquit gear. Did you have the Ubiquiti device set to VHT80 channel width on the 5 GHz?  Was there a guest network setup on the system?
Message 79 of 252
rafale7
Apprentice
@st_shaw
Yes all were using VHT80 channel. Performance wouldn't be able to reach above 400Mbps without it. And no guest network. My set up has a separate SSID for 2.4GHz though and it was set exactly the same to make it a drop in replacement. I spent some time on the ubqt forum and it is pretty consistent with what others have observed there. Even if all the devices are 2x2 you will see significantly lower performance with multiple clients compared to Apple. In a "connected home" the single client performance is useless since we are to expect 5-20 clients per AP. ubqt own data showed aggregate throughput to be very limited in multi user environment and are releasing the HD with a 4x4 radio at a whooping $350 a piece to improve it. If it was $150 I would have considered it but not at $350.
That being said I am considering changing my setup to increase range and if possible speed and I have to say, ubqt is not the answer. Both speed and range are reduced dramatically. It could be that the LR has higher range but being a 2X2, it would be a downgrade for speed. The major problem seems to be the processing power of the unit.
The controller was a pain to install on ubuntu server and took a lot of community help/try and error to get to work but is very attractive, informative and functional so I understand the hype.I am just very disappointed by the hardware performance and can only say there is a lot of overhyping going on.
Peak Single client
AC Pro: ~600Mbps
Airport AC: ~820Mbps
Can see here:
I don't have the 10 client stress environment to compare to this dataset but my low 15 client test shows:
AC Pro: ~450Mbps
Airport AC: ~600Mbps
Note also that these are not peak throughput. I am actually 15ft away one floor down from the AP for these tests.
Message 80 of 252
st_shaw
Master
Thanks, @rafale7. I'm surprised you could get 600 Mbps from so far away.  I've read that Apple is discontinuing their WiFi APs though.  Strange, since they seem to perform well.
Message 81 of 252
financial decision based on how much they would make on routers etc v how much they make on phones and tablets
Message 82 of 252
st_shaw
Master
Yeah. Seems like it's getting harder and harder to find high-performance products anymore. People don't want to pay for it. The phone market is also making it harder to find high performance electronic components like accelerometers and magnetometrs.
Message 83 of 252
rafale7
Apprentice
Indeed. The rumor is that the development team from Apple's router have been reassigned to the AppleTV product. It means no new product or developments in the foreseeable future but when I look at the market offering and the development in the past 4 years, I can see why. There isn't any significant breakthrough. Their 4 year old product is still competitive and and a lack of innovation/differentiation means lack of revenue $.
And note that the Orbi is not too shabby. It is actually pretty close and far ahead of the ubqt. The hardware is good. Software/firmware needs some work which is the opposite of ubqt. The single biggest differentiation is the 1.7Gbps wireless backhaul which can feed a satelitte broadcasting at 1.3Gbps (+450Mbps at 2.4GHz). The 5GHz AC radio itself, the ethernet ports and the processing power are all there. Just need to make it run right. Netgear has the right idea.
I think UAP AC's concept is a wired mesh with weak APs compensated by numbers and having them work in concert coordinated by a separate controller and router. It appears to have been designed for 2x2 devices with low throughputs. Each AP, having more of them, would then have to handle fewer clients and needing less bandwidth. The issue I see with this is the intrinsic bandwidth of each AP is too low and not future proof. The new HD really is adding more processing capability more than the extra antenna and radio giving the abilty to handle more throughput.
If netgear could make the orbi router the controller and each satellite having the ability to connect wirelessly to one other satellite and wired to the router. Or be connected to the router wirelessly, you would get the most flexible and powerful wireless platform. For now, I guess I am returning all the new gear.
Router --- (wireless backhaul) --- Satellite
(wired backhaul)
Satellite --- (wireless backhaul) --- Satellite
(wired backhaul)
etc...
Message 84 of 252
TheEther
Guru
Some of you are mixing up two of Ubiquiti's products.  The Amplifi is their mesh system.  The UAP AC is part of their Unifi lineup of wired Access Points; they have no mesh capability.
Message 85 of 252
and just confuse things even more there is now unifi mesh
https://unifi-mesh.ubnt.com/
Message 86 of 252
rafale7
Apprentice
In My case, I did not confuse the products. I was just using the word mesh inaccurately.
What I meant by it was to say that the APs are able to talk to one another and steer devices to the AP with the highest signal which the unifi can do and.
The Orbi is really not a mesh network neither.
Message 87 of 252
this can only happen if the clients are capable of understanding and moving , most devices / clients arnt compatible with that standard yet
correct orbi is a distributed wireless system , not a mesh system
Message 88 of 252
TheEther
Guru
If you are thinking of 802.11r, iOS has supported it for quite some time.  It also supports 802.11k and 802.11v.  source.  Android, I beleive, has supported it since Lollipop.  source
I know you understand what Orbi is, but this distinction may be too subtle for some to understand.  This picture may help others.
The Orbi uses the setup on the right, with the base station in the middle.  A true mesh system (i.e. one that supports 802.11s) is on the left.
Message 89 of 252
iHeijoushin
Initiate
Linksys' Mesh Velop  system utilizes both a dedicated wireless backhaul like the Orbi and offers ethernet backhaul - giving the best of both worlds.
However, the Velop's lack of extra ethernet ports, like the Orbi, gives me pause. As the competition for mesh system heats up in 2017, Netgear would really be foolish to leave this feature out forever.
I'll just sit and wait and continue resenting my pair of R6400 in clunky AP mode.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 90 of 252
JMU1998
Luminary
@iHeijoushin Please request it here in idea exchange there is petition on going for it more voices more attention it gets, I believe it is on the cards but no ETA
https://community.netgear.com/t5/Idea-Exchange-For-Home/Netgear-Orbi-Wired-Sattelite/idi-p/1145210
The more people thumbs up and state their use case more likely it will be added sooner rather than later, right not Engineering has bigger fish to fry with stability and disconnect issues.
Message 91 of 252
Dirtduff
Initiate
I just purchased the Orbi system from Costco with Router and 2 satellites. Unlike eero and other comptetors there is no ethernet (wired) connection on the Orbi satellites. Big disappointment. My house is large and is wired for 4 ethernet ports.  Several rumors on the various blogs state that the ORBI satellites will get a firmware update that will enable one of the 4 ethernet ports on the satellites to function as a backhaul connection to the router.  Is this true?  Its a shame to use a wireless connection when I have a wired ports available throughout my house. Also, in addtion to using a network switch at the ORBI ROUTER i will need to use a network switch AND an Orbi satellite at each wired ports in my house, rather than just an ORBI satellite with one ethernet backhaul.  This will result in daisychaining switchs and I have heard that daisychaining switches is not good. Costco allows 90 days for returns. If the firmware update does not happen within 90 days I will return the Orbi and purchase a few Apple Airports.
Message 92 of 252
interestingly you have read there might be an update and you where aware that it didnt have ethernet backhaul yet you purchased the orbi and are now disapointed !!! , wether it will ever get or at some stage get ethernet backhaul is anyones guess as its been talked about forever and nothing from netgear as far as an official response goes , not even a suggestion at this stage
if you have structured ethernet runs in the house why would you want any mesh or distributed wireless system anyway , all you need is a few well placed wireless access points or wireless routers with AP mode
its been almost a year since the orbi was in beta and then released and all that time ppl have asked for backhaul ethernet and nothing has come of it and tbh i dont think it will in the next 90 days although wonders never cease to amaze me , perhaps ethernet backhaul on the orbi will be one of them that do
Message 93 of 252
Random12
Apprentice
Netgear acknowledged this request and said they are considering it, but didn't confirm that it will happen for sure. The post I read from a Netgear product manager is on this forum here somewhere, in one of the ehternet backhaul threads.
Message 94 of 252
and they have been "considering it" for almost a year with not a further word
what i think is we may see a orbi 2.0 with ethernet backhaul , but at this stage the workload just to get the current issues fixed and working is still to be addressed
until we see an announcement that its been added i wouldnt get excited at all about if and or when or even at all
Message 95 of 252
selsrog
Tutor
I'll be returning my gear as well.
Forgot to check the existance of the ethernet backhaul (as I imagined it was available).
Cannot wait for the firmware update... If it ever sees the light of day...
Message 96 of 252
rafale7
Apprentice
I returned mine yesterday. It is too bad because they were performing quite well but did not fit my use case. After thinking about it, Not to second guess the netgear engineers and marketing guys but being in the tech field doing both jobs myself, I would have adopted a slightly different product strategy:
1. I would have made the routers and satellites interchangeable given the fact that they are physically identical in terms of hardware. It would have saved cost by releasing a unique unit and lowered the inventory management.
2. I would have designed it with the flexibility of the ethernet backhaul, used a 3x3 broadcast radio with the 4x4 backhaul
3. limited the backhaul to 2 satellites to maintain performance of the wireless satellites.
I spent some time testing different 2x2,  3x3, and 4x4 APs with a single clients on the 5GHz AC band for those who think the unifi AC lineup is anywhere close to an upgrade, think again. they are practicaly the slowest AP you can buy with the exception of the just off the mill AC-HD which is finally using a decent/enterprise chipset. The others use a chipset only found in a couple of very poor budget N or "AC was an afterthought" routers. The AC-Pro achieved 25-50% lower speed vs the Apple AP at most locations in spite of using 50% (6 Vs 4) more units in my topology.
Message 97 of 252
JMU1998
Luminary
Any update from Netgear Engineering on this wired backhaul feature?  Do any Mods have any additional info to share with us on this topic if Engineering are considering this as a future enhancement request? Netgear Idea exchange has it as the most popular feature requested.
Message 98 of 252
AmitR
NETGEAR Employee Retired
Let me acknowledge that our customer base has been clamoring for this feature for a while, and we are trying to be responsive to their needs.  To provide context on why it's taking a while to get it out, during the first quarter, the Orbi Engineering team was focused on bringing out the two new products (RBK30 & RBK40) to market.  Now that it's accomplished, we're actively working on bringing this feature and a couple of other interesting, market-requested features to you.
Orbi Product Team
Message 99 of 252
JMU1998
Luminary
@AmitR this is fantastic news that wired backhaul is in the works a feature most welcome and highly desired and being requested for a while by the community.  thank you for the update and good news we eagerly await the firmware that will make this a really.  thank you Engineering for listening.
Message 100 of 252
Top Contributors
Announcements
Orbi WiFi 6E
