- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Foscam C1 Cameras
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Hoping someone can help me so I can keep my Orbi!
I have several Foscam C1 cameras that operate only on 2.4ghz frequency. When setting up, my phone needs to be connected to a 2.4ghz signal, but with the Orbi it forces to the 5ghz signal, preventing me from setting up my cameras.
Is it possible to set up these cameras with the Orbi? If not I'll have to go a different route...
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Turns out the fix for me was not to plug each camera in via cable, but rather to DISABLE Enable 20/40 MHz Coexistence for 2.4 ghz band via ADVANCED > ADVANCED SETUP > WIRELESS SETTINGS. Hope this helps others.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Foscam C1 Cameras
Hi, figured it out! Get to keep my Orbi. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi - may I ask what the fix was for this? Am having the same issue with Netgear Orbi and Foscam IP cameras. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI,
You need to plug in each Foscam camera, one at a time, into your Orbi router via an ethernet cable and then configure.
Good luck!
- Mark as New
- Bookmark
- Subscribe
- Permalink
