- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Hardwiring my Satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’ve tried changing channels and it hasn’t really seemed to make a huge difference. The zoom calls are random times even when I’m the only person In the house using WiFi.
Suggestions?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So your recommendation would be to hardwire the satellites?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Hardwiring my Satellites
Some more details.
1. What firmware is on the router and the satellites?
2. What modem/gateway is the router connected to?
3. What speeds (both upload and download) do you pay for?
4. What actual speeds do you get hardwired into the router?
You can hardwire the satellites in and it can help speeds, especially if the wireless backhaul was the issue. But if the wireless backhauls running great, that might not be the issue.
What is Ethernet backhaul and how do I set it up on my Orbi WiFi System? | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
2. We have a charter/Spectrum modem
3. 200mbps is all I can find on my bill? We have spectrum Internet
4.not sure about the speeds when I hardwire as we have not tried this yet. I was curious to see if it would help to hardwire.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@plemansis correct that many factors influence performance.
200mb is entirely adequate for Zoom meetings (I have 200mb from Spectrum and we Zoom and Facetime many times a week).
The question about hard wiring was intended to verify that Spectrum is actually delivering 200mb.
When a computer (desktop, laptop) is connected directly to the Spectrum modem with an ethernet cord, that is the highest speed possible.
If this is inconvenient or impractical, then the Orbi Speed Test is an approximation.
The 'backhaul' network is also critical, especially if the satellites are "Daisy Chained". i.e. Floor 2 connects to Main Floor, which connects to Router. That makes two "hops". If this is the problem, then hardwiring both satellites directly to the router will make a huge difference.
Performance over an ethernet backhaul connection will be dramatically better than performance over two WiFi hops.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Another consideration is that problems with video chats (Zoom, Facetime) can be caused by factors outside of your WiFi network, such as at the "other end."
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Leex1681 wrote:
If I’m understanding correct, daisy chain is how I have it set up now? Each satellite on different floors not hardwired yet.
On the Orbi web interface, Attached Devices page, the satellites are listed at the top of the display. The column "Connected Orbi" shows what each satellite is connected to. If one satellite connects to another instead of the router, that is Daisy Chain.
If connecting the satellites directly to the router with ethernet cable is practical, it removes Daisy Chain from being a possible cause of problems. I would wire my satellite with ethernet except that I cannot find a way to place a cable between them. (Damn these two story houses with no crawl space under the floor and no attic access to every room.)
If installing ethernet cables is a major effort, it is possible to test what happens by using temporary ethernet connections.
Amazon sells 100ft. ethernet cables for under $20. The family may tolerate cables running up the stairs, through the hallway, etc. for a couple of hours. Convert to ethernet backhaul and start up a Zoom meeting. Better? install cables. No Better? Not the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Amy
