Reply
How To Set Orbi WiFi Router To Never Change Internal IP Addresses Of Devices (For Portforwarding)
Hello,
So, on my Netgear Orbi Wifi Router, I have port forwarding configured for one of the devices on my network. However, the newest spot of bother I am having with this is that occasionally, after a reset or something of the sorts, the router will assign the devices on my network a new internal ip address which disrupts the port forwarding of my device and I have to go into the router settings and reconfigure the port forwarding rule to the new ip (or device name) address the router has given my device. I am wondering, is there a way to configure the orbi router to always assign the same ip address to this device?
Thank you.
Model: RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 2
Accepted Solutions
Guru
Re: How To Set Orbi WiFi Router To Never Change Internal IP Addresses Of Devices (For Portforwarding
Set an IP address reservation ON the router for the devices. This will keep same IP address for each device.
Found under Advanced tab/Setup/LanSetup/Add button.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 2
All Replies
Guru
Testing
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1323 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
