Nothenemy's avatar
Nothenemy
Follower
Feb 23, 2019
How do I locate browser history in the ORBI menu? I'd like to block certain URLs.
How can I block a URL or two in the Orbi menu? I have been looking for a history window and haven't found one. Home network. Windows 7. Orbi has latest version of firmware.
  • You can block URL’s on the web GUI under >> ADVANCED >> Security >> Block Sites
    You can block the sites always or according to a time schedule.
    You can also use Circle to do the same per user.
  • michaelkenward's avatar
    michaelkenward
    What "history" are you looking for?
    Your Orbi does not remember sites that you visited. That is down to the browser.
    • ekhalil's avatar
      ekhalil
      Master
      Otherwise you can also use Circle to see history of visited sited by all devices per user:
