Orbi WiFi 7 RBE973
Reply
How to disable 2.4G in my Orbi
Iamnobody
Hi,
I have a Orbi, but how can I disable the 2.4G, I don't want to use it.
Otherwise, What is the connection between Router and Satellite? Is it 5Ghz?
Message 1 of 5
schumaku
Guru
Re: How to disable 2.4G in my Orbi
The Orbi wireless distribution mesh based on dedicated a AC1750 5 GHz band radio, independant of the 5 GHz access point radio.
If there is no control to enable/disable the 2.4 GHz radios ...
-Kurt
Message 2 of 5
Iamnobody
-Kurt
Hello Sir,
If my understanding is right, that means I won't get link rate over 866Mbps in 11ac even my client is 3x3, because the backhaul used it, right?
I can't find any button to disable 2.4GHz on GUI, there is only a button to hide 2.4G SSID boardcast, however, Orbi only allows one SSID for 2.4G & 5G, why is no way to enable/disable 2.4GHz.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 3 of 5
TomMac
Guru
@Iamnobody wrote:
Hi,
Go into main router , go to advanced >advance setup>wireless settings
toggle off 2.4 radio, save and exit
Message 4 of 5
schumaku
Guru
Correct. FIts to my observations, several test reports, and last but not least Netgear KB: At what speed and bandwidth can my Orbi system transmit data?
The math and the marketing aspect of "AC3000" was discussed before, ie. here https://community.netgear.com/t5/Orbi/Orbi-AC3000-or-really-AC1266/m-p/1172945#M1150
Answered above by @TomMac Have no Orbi accessible as of writing..
-Kurt
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 16303 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
