YogaMan's avatar
YogaMan
Follower
Mar 08, 2019
How to disable all WiFi Bluetooth Air Signals on Orbi Voice w/ Amazon Alexa? AC3000 (RBK50V)
Can I disable all WiFi / Bluetooth / Any Air Signals and just use direct connect Ethernet? Will I loose any features?
Thank You
  • YogaMan wrote:
    Can I disable all WiFi / Bluetooth / Any Air Signals and just use direct connect Ethernet? ......
    Not using normal configuration but you can disable wifi interfaces on the node using telnet commands.
    YogaMan wrote:
    ....... Will I loose any features?
    You will just loose the wireless connectivity to the Satellite so it will not be part of your mesh network!
