DougB628
Jan 17, 2019Apprentice
Inconsistencies in Orbi Attached Devices Page
The Attached Devices page has inconsistencies in the "Connected Orbi" column. I've included a screen shot with the inconsistencies circled.
In particular, I'm wondering why in some cases it shows the MAC address of the Orbi Satellite, but others it does not. It also sometimes uses the name "Orbi Satellite", even though I've renamed my Satellites.
- ekhalilMaster
1. In the screen shot that you provided I can't see any device connected to "1st Satellite". Are the devices shown as connected to "Orbi Satellite" connected to "1st Satellite"? Do you ever see "1st Satellite" in the list?
2. Please provide us with some information about your setup: Is Orbi in Router or AP Mode? Is the ISP modem only a modem or does it have any routing functionality?
- DougB628Apprentice
On the router's Attached Devices page, only two devices show as being connected to 2nd Satellite, and both are visible in the screen shot. 1st Satellite never shows in the list, and the devices that show as connected to "Orbi Satellite" are actually split across both satellites.
At the moment, the router shows 39 devices on its Attached Devices page, 1st Satellite shows 14 devices, and 2nd Satellite shows 11 devices. The router says there are 16 devices connected to Orbi Router. 16+14+11 = 41.
I've also seen devices that show as connected to Orbi Router also show as being connected to one of the satellites. Right now my daughter's phone shows on the router's attached devices as connected to Orbi Router, but it also shows on 2nd Satellite's connected devices page.
My Orbi Router is in Router mode, and my modem is an Arris cable modem that is only a modem. It has no routing capability.
- ekhalilMaster
- For testing purposes, can you please change the satellite names to something simpler with no spaces in between.
- Can you please also test to add IP reservations for the satellites in >> ADVANCED >> Setp >> LAN Setup.
- Ragar99Luminary
I've seen the same after changing the names, it's a bug.
