Quickslide
Jul 10, 2017Follower
Is Orbi a mesh network?
Is Orbi a true mesh network?
I need to be able add Satellites to my network (when they become available). Do they satellites talk to one another and connect back to the router?
Hello Wodpqldcmff
It is star topology so you would want the main router unit in the middle of the satellites each satellite needs to communicate to the router you can not do satellite to satellite.
DarrenM
- netwrksMaster
Nope. It's an extender network with a high speed wireless backhaul (1733Mbps). YMMV, on the backhaul as it is wireless, and environment plays a role in wireless technology. They connect to the router only. Not to each other.
If I had a building that was shaped like a rectangle, and lets say the building is 1000 feet long, could I install an Orbi router at one end (RBS50), and individual RBS50's or RBW30's in a daisy chain type installation, where if the furthest Orbi (RBS50 or RBW30) from the router could not talk back to the 1st router, would that furthest Orbi attempt to mesh with the closest Orbi?
It would look like this...
RBS50 (then 150 feet) RBS50 (then 150 feet) then RBS 50 (then 150 feet) "would this next AP have to communicate back to the RBS50 router or the closet Orbi?
- AmitRNETGEAR Employee Retired
The question is: what problem are you trying to solve? What Orbi does is provide whole home coverage, under a single network name, seamless roaming, single management view. it doesn't use the traditional mesh protocols because they trade off speed for coverage but instead, it leverages the tri-band to connect via the dedicated wireless connection.
You are able to purchase additional satellites and add them to an existing system and they'll inherit the components of the system (single SSID, seamless roaming, etc).
- DarrenMSr. NETGEAR Moderator
Hello Wodpqldcmff
DarrenM
Bummer, but thanks.
