- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is there an upgrade path from Wifi 5 to 6 for an RBK50 owner?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBK50, so a RBR50 router and RBS50 satellite. I need a 3rd satellite for better coverage upstairs.
First, are there any plans to upgrade the RBR50's to WIFI 6 via firmware upgrades?
Secondly, is there any planned compatibility between the newer wifi 6 orbi's and the older ones?
Wondering if I just wait for the prices to come down on another RBS50 and skip Wifi 6 altogether. This is just for home and home office use.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is there an upgrade path from Wifi 5 to 6 for an RBK50 owner?
@wolfereeno wrote:I have an RBK50, so a RBR50 router and RBS50 satellite. I need a 3rd satellite for better coverage upstairs.
No. Cannot be done. Requires a different radio chip.
Netgear has hinted at compatability to allow the existing satellites to work with the WiFi6 router. Apparently some users have satellites working when "wired" to the WiFi6 router, but connecting satellites with WiFi backhaul has not materialized.
The RBS50 is the most costly indoor satellite. There are others that cost less and work seamlessly with the Orbi router. In 5 years, there will be enough WiFi6 devices in use to make having WiFi6 really useful. For the next 2-3 years, it won't make any impact on you at all.
If you need more WiFi coverage now, I would get more now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The RBK50 is not HW compatible or has any HW support for WiFi 6. Orbi AX systems has already come out and is WiFi 6 Supporting:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
NG is supposed to made the RBS50 satellites compatible. Not sure when though.
Wondering if I just wait for the prices to come down on another RBS50 and skip Wifi 6 altogether. This is just for home and home office use. If the 50 series is working well for you, keep it. Until you get more devices with AX wifi, not a real need to upgrade until then.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK thanks guys.
I'm sure I need the additional coverage. I have kind of an unusual multi floor apartment.
The RBS50 seems to cost almost as much as the whole 2 unit RBK50 kit so I've been trying to just wait for a sale. I could get the two radio version RBS20 but I'd rather get 50 if the prices drop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hope you can find something that works for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My perspective is that WiFi 6 is still very much a work in progress. Not all features are implemented yet.
WiFi 6 does support better hardware and hence can support faster internet and more devices.
I only have 40 down and 3 up (bonded DSL). I won't be upgrading to WiFi 6 anytime soon.
If you are sporting gigabit internet and a ton of devices, then I might look into it. Otherwise, newer/better hardware is always coming out and in a few years there will be a much better WiFi 6 Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
"Orbi with Wi-Fi 6 is expected to be available on the Orbi RBK50 series in the second half of 2019."
https://www.netgear.com/about/press-releases/2019/NETGEAR-ANNOUNCES-ORBI-MESH-WI-FI-SYSTEM.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
@wwwXpert wrote:
According to this Press Release, wifi 6 will be available on the RBK50.
Alas, the same press release talks about Qualcom's "new SoC" (System on Chip) that makes WiFi6 possible.
Not new firmware. New chip.
WiFi6 did come out in 2019, and it is NOT available on the original RBK50 product and never will be.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe that is a typo. "Orbi RBK50 series in the second half of 2019" I believe they meant to say RBK850 series which did debut second half of 2019. The 50 series Orbi AC will not see any such upgrade as wifi 6 is a whole new chip set and hardware which means implemenation of new HW which can't be added to older hardware. This new products and models were released, Orbi 7 and 8 series AX is now out in the wild.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was in the same boat and it appears the RBS50 is discontinued. All I can find are refurbished and used units which is another reason prices are so high.
I ended up pulling a trigger on a RBS50Y and going to put it in my garage or on my deck. Where originally I was going to put the RBS50 on the other side of the wall inside. This though forces me to wireless backhaul since the RBS50Y doesn't have Ethernet ports.
I didn't want to yet buy a completely new Orbi system/kit as my RBR50 is only 18 months old.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@wwwXpert , An RB50 device can't support WiFi 6 fully . It would need newer hardware to support the 802.11ax requirements.
Where I could potentially see mixed use in the future is using the Orbi WiFi 6 Router (RBR750, RBR850) with an Orbi WiFi 5 Satellite until the user completely converts to 100% WiFi 6.
I say in the future because right now the firmwares between the WiFi 5 satellites and WiFi 6 routers can't communicate. There are a ton of complaints on the Outdoor RBS50Y forum and reviews that they aren't currently compatible and there currently isn't a WiFi 6 outdoor satellite.
I think where Netgear confuses people in their marketing is the Kits change the last digit to account for the number of devices in the kit when they released the 2 satellite kit with the RBR50.
For Example
WiFI 6 Devices:
RBK853 -- Is a RBR850 and 2 RBS850s
RBK852 -- Is a RBR850 and a RBS850
WiFi 5 Devices:
RBK53 -- Is a RBR50 and 2 RBS50s
RBK50 -- Is a RBR50 and a RBS50
