Reply
LBR20 — Orbi LTE Tri-band WiFi Router - Verizon Wireless?
WayneU
First, I apologize for putting in Orbi Pro in the Location.  It would not allow me to put in the LBR20 Orbi.  Perhaps the model is too new and the website has not been updated.
I have owned the Orbi Pro system (model SRK60-100NAS) and am very happy with it.  But now, I am interested in purchasing the LBR20 — Orbi LTE Tri-band WiFi Router.  I live in a very rural and sparesely populated area and the only cellular carrier is Verizon Wireless.  Will this device work on the Verizon Wireless Network?  If the answer is 'Yes', I will purchase this today!
If the answer is 'No', then could you point me in the direction of a Netgear product that does connect to the Verizon Wireless Network, and also connects to an Ethernet Router via an Ethernet cable?
Message 1 of 8
Guru
Re: LBR20 — Orbi LTE Tri-band WiFi Router - Verizon Wireless?
It seems like it does.
Some had some initial issues but got it working.
https://community.netgear.com/t5/Orbi-LTE/LBR20-with-Verizon/td-p/1965136
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 8
ssmitty67
I have had the Orbi LBR20 since late August and can tell you it does NOT currently work with Verizon.    I have constant disconnects and I have been told by Verizon that the IMEI of the device is not recongnized by Verizon.
I have also been told by Netgear that is is not certified with Verizon and they cant tell me excatly when it will be, but couldn be in Q4 or Q1..
I really wish it worked, as when i is not disconnecting, it works great.
https://community.netgear.com/t5/Orbi-LTE/LBR20-keeps-disconnecting-from-LTE/m-p/1968464/highlight/t...
Message 3 of 8
Guru
@ChristineT Any update on working with Verizon?
Message 4 of 8
WayneU
Thanks very much for taking the time to provide me with good information.
Message 5 of 8
WayneU
Thanks!
Message 6 of 8
Guru
Please post about this over in the Orbi LTE forum for this model Orbi:
https://community.netgear.com/t5/Orbi-LTE/bd-p/en-home-orbi-lte
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX80 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 7 of 8
WayneU
Ok. Will do. Thanks for pointing me in the right direction.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1137 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
