martin240's avatar
martin240
Lightning storm
Lightning took out our cable connection a couple days ago, comcast just got over today to fix it. My RBR40 had been magenta since we had no internet but now everything is replaced w a new modem also but the RBR40 won't detect the ethernet cable. I've replaced the cable w unused ones. I also tried resetting the router since it took FOREVER (like an hour) to stop blinking white & I thought maybe it was just the new modem causing issues. Is this thing bricked? Did the storm somehow knock out my router? Bought this in 2019. If so, which if any newer systems will work w my 3 RBS20 sattelites? Thanks for your help!
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed?
  • CrimpOn's avatar
    CrimpOn
    I once had a lightning strike destroy a floor furnace, so yes, it certainly is possible that the Orbi has been fried.
    For certain, there is no harm in doing a Facctory Reset on the router:
    https://www.youtube.com/watch?v=cMw4ePACgc4
    If the Power LED on the back does not turn green, then the box is dead.
    Any of the original Orbi router models will work with your satellites:
    RBR50, RBR40, RBR20.  The "Pro", "AX" and the new "10 series" will not.
    • martin240's avatar
      martin240
      Yes a power down has been performed several times as well a factory reset. The power light is green but it can't see the internet coming in from the ethenet cable, which is active, I plugged that cable into my computer & verified. I'm guessing it's toast & at this point I'm tired of watching tv from my phone lol.
      martin240
      Do you know if the RBK50 router will work w my existing RBR20 satellites?
      • CrimpOn's avatar
        CrimpOn
        Yes. The RBR50 router will work with the existing satellites
