maverikv's avatar
maverikv
Magenta Light on Router, no Internet Many times a Day
I've upgraded to the latest firmware and it keeps happening. Constantly having to reset my router. Turned off Daisy chain topology and uPNP, still happening. How can a $400 router be this bad?
  • Retired_Member's avatar
    Retired_Member
    Magenta usually means your SAT is too far from the router.
    Whar firmware on you on?
    Did you upgrade it manually?
        Retired_Member
        The firmware you downloaded is not ready for prime time?
