Orbi WiFi 7 RBE973
Reply
NETGEAR -Orbi AC2200 Tri-Band Mesh Wi-Fi System RBK43-200NAS
prue
I’m trying to get help on the Orbi AC2200 Tri-Band Mesh Wi-Fi System RBK43-200NAS but it’s not an option under model.
I’m not getting the speeds in the upper corner bedroom. I have the router placed on the main floor with one satellite in the garage for security cameras and the other satellite at the top of the stairs on the second floor near the bedrooms.
When I tested the speeds the day I installed the system (yesterday) my speeds were 175 (we pay for 175) but today the far corner bedroom is running on 2.4g at (30mbs) and cant seem to get the 5g speeds even with the satellite 10 feet away.
The reason we got this unit and spent $400 is to be able to get 5g speeds (150-210) in the bedrooms. Rethinking the Orbi mesh.
Can anyone suggest or help? Am I missing something?
Message 1 of 4
Guru
Re: NETGEAR -Orbi AC2200 Tri-Band Mesh Wi-Fi System RBK43-200NAS
Message 2 of 4
prue
Thanks.
I’ll get you the responses.
Meanwhile, how do I find out nearby WiFi neighbors? We do have neighbors using WiFi.
Thank you.
Message 3 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 463 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
