ARoesberry's avatar
ARoesberry
Follower
Apr 24, 2020
Netfear Orbi RBR20
Over the last week our family has had to reset our Orbi RBR20 router at least once a day, as the signal goes out several times a week. Today (4/24/20) ot reset once and then lost all connectivity to the internet. I purchased a new ethernet cable this morning to see if that would make a difference, but no luck.
We purchased the modem in Oct. 2018. Previous routers have lasted us 3-5 years. This one...not quite a full 18 months.
Anyone have any other solutions or is it just needing to be replaced?
  • FURRYe38's avatar
    What Firmware version is currently loaded? v16 is most current...
  • CrimpOn's avatar
    CrimpOn
    It's probably a typo, but I simply LOVE the spelling: "Netfear".
