- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI and Amcrest/Foscam
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently had verizon switch my older coax for ethernet so I could switch to ORBI. The ORBI system worked great and I get excellent coverage.ut f
The only strange occurrence is with AMCREST/FOSCAM. I have about 4 of them. I have used them all for multiple years and know how to port forward and use them with Blue iris. SO I did a factory default on all 4. But for some reason I am not able to log into 3 of three of them and none even seem happy to connect to wifi. I tried using the verizon as a secondary router and connect to it and still have an issue.
I know there has been some discussion on this about 2.4GHZ connectivity but find this pretty strange I can see one camera
The FI9803 outdoor cam is an issue'
The Foscam C1 will connect but will not allow me to log in wirelessly
And IP3M-941B will let me log in and I can see it remotely but not with blue iris
I hae an identical IP3M-941B at another location and have no issues with viewing it ( same settings) and I double checked the password
In short, can any one either help or recommend both an IP Cam for indoor and outdoor use that works well with orbi? many thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI and Amcrest/Foscam
If you put the older wifi back online and they still have problems conneting it it, I presume there maybe problems with the cameras.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-...
Try changing the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. The Foscam's are all working but I stil have problems with the Amcrest for some reason. I set up port forwarding on the router. I can easily see the port is open on canyouseeme.org. But when I try to view them on blue iris.. nada. I know how to use blue iris and have not experienced this before. I ditched the verizon router. Other than that one quirk, the Orbi system works perfectly. I will ditch the old amcres cameras and pick up a few Foscams. I am not using many cameras.
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe this thread will help you:
https://community.netgear.com/t5/Orbi/Orbi-AC3000-and-Amcrest-wireless-camera/m-p/1388576#M14629
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have found this software very useful in setting up the AMcrest cams on the Orbi 3000
https://sourceforge.net/projects/onvifdm/ All of the cams work fine now . thanks to all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
