mlmdjd's avatar
mlmdjd
Tutor
Jun 26, 2020
Opening ports on Orbi for magic jack
I am having trouble with my Magic Jack phone device. I have done extensive troubleshooting with them as well as replacing devices, cords, etc. They keep telling me to make sure ports 5060-5070 are open. I have gone into my router settings and done this. I have looked at my user's manual and followed how the manual says to do it. However, Magic jack says it cannot be done that way and only my ISP can do this. My ISP says they cannot do it as they do not own the router. What is correct and how do I do this? Thank you to anyone who can help me.
  • Port forwarding is setup by you, not your ISP.  You control your router (Orbi) and also the internet device, e.g., cable modem.
    1. What is the cable modem or ISP device you use to get internet?  Is it just a modem or can it also be a router/wireless/etc.?
    2. Use https://canyouseeme.org/ to see what it reports for the ports you're trying to open.
    3. Verify that the IP address it reports matches the Internet Port IP displayed by your Orbi.  If it doesn't match then you probably have Double NAT. i.e., your cable modem is also a router so it needs to be put into bridge mode or also port forward to your Orbi.
    4. Give us a screen shot of your Orbi Port Forwarding settings.
    5. From https://www.phoneservicesupport.com/port-forwarding-instructions-for-the-magicjack-plus-guide-t12420.html it looks like you need to port forward 5060, 5070, 49152, and 65525.
    • mlmdjd's avatar
      mlmdjd
      Tutor
      Thank you. I finally had a chance to try this. Let me say first, though, is that I am just an average person and not a tech person. I can follow directions and do many things but if I sound unsure or a bit "ignorant", please forgive me. I was trying to attach 3 screenshots but I am not sure they are coming through. So, I will try to just insert them below.
      1. My modem is my own and not supplied by my ISP (Comcast). It is a Motorola Surfboard eXtreme, SB6141. I see nothing about it also being a router.
      2. When I ran the Open Port tool, it could not see the ports indicated by Magic Jack. I followed the instructions for opening the ports including restarting the modem, router and computer but the result was not changed. Here is the error message.
      Error: I could not see your service on 73.34.202.242 on port (5060)
      Reason: Connection timed out
      Your IP:
      Port to Check:
      3. You indicated to make sure "the IP address it reports matches the Internet Port IP displayed by your Orbi." The tool displays the IP address for Comcast and it is the same as the IP address on the "Internet" tab on my Orbi settings page.
      Under that tab and the section for "Internet IP Address" , it says "Get dynamically from ISP" and it shows the same IP address as in the above error message. Is that what you were asking?
      4. I (hopefully) attached a screenshot of the port forwarding settings page as requested.
      I haven't tried phone calls, yet, as it appears as the ports are still not open using that tool you provided. I'm not sure if I did something incorrect or if it is something else.
      Once again, thank you for your help and any more advice/suggestions would be greatly appreciated!
  • FURRYe38's avatar
    I found best and easiest method for VoIP devices is ot use the routers DMZ.
    Be sure your ISP modem doesn't have a router built in as well.
    • mlmdjd's avatar
      mlmdjd
      Tutor
      Thank you for your suggestion. I do not know what DMZ is. Could you direct me to a source that could explain it to me?
      • Your replies to my earlier questions were good.  It looks like you do have the port forwarding setup and your Orbi is the only router (i.e., you do not have Double NAT).
        One last question - How do you know that your Magic Jack device is at 192.168.1.6.  When you go to Orbi's admin website and click on Attached Devices do you see the Magic Jack device listed and with that IP address?
        The suggestion for DMZ (demilitarized zone) is to setup your Magic Jack device so that it is exposed to the Internet and not protected by your Orbi router.  In Advanced... Setup... WAN Setup you can enter one IP address for Default DMZ Server and check the box.  This works if you know your Magic Jack device's IP address.  If you setup DMZ then you don't need to worry about individual port forwarding setups because all ports of the device are exposed.
