KKCAUS's avatar
KKCAUS
Orbi NBN connection via Netcomm AC modem (Aussie Broadband FTTN NBN)
Appreciate any help to setup Orbi to connect to Aussie Broadband FTTN NBN via supplied Netcomm AC modem router. Understand that I can connect with Orbi setup in AP mode but read somewhere that I will loose some functionality in AP mode. Few questions below:
- is there any lose in functionality while in AP mode? I current setup IP assignment and access in Orbi.
- what is the steps to connect thru the supplied Netcomm AC modem while turning off Netcomm Wifi. Read that Aussie Broadband use IPOE. Need to know which settings in Orbi to setup.
  • FURRYe38's avatar
    Most of the routing and control features are disabled on the Orbi when in AP mode.
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode thus claiming back all features of the Orbi.
    3. To setup AP mode, disable all wifi radios on the modem/router and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • KKCAUS's avatar
      KKCAUS
      Thank you for the feeback. Will check with Aussie Broadband on how to setup the netcomm wireless router to transparent bridge mode.
      Are there any setup required at Orbi side besides setting it in router mode?
      • raven_au's avatar
        raven_au
        Virtuoso
        There shouldn't be.
        All that's happening here is your making the ISP router behave like it's a modem only.
        The ISP router might not turn off its WiFi so watch out for that becuase it will interfere with the Orbi WiFi, there's simply not enough wireless channels available for both to be active.
        I've seen posts saying Aussie Broadband are very good so I ecpect they will be willing to help.
        I'd be very surprised if the Netcomm couldn't be set to bridge mode and I think that's the best way to handle this. In fact I have used my iiNet Technicolor in bridge mode just fine with the Orbi, although it was really hard to find out how to set it to bridge mode (I wasn't willing to even ask iiNet ...).
        Ian
