Orbi WiFi 7 RBE973
Reply
Orbi RBK50 Firewall Blocking ESET Antivirus Updates
DK62
I use ESET antivirus on my mac computer running OS Catalina. I've recently installed an Orbi mesh router in my home. Now my ESET gives an error when trying to update the virus signature modules. I've isolated the problem to the Netgear Firewall (when I connect my computer to the internet via a cellphone on a different network, the modules update fine). How can I fix the Netgear firewall to allow ESET to update modules?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 7
Guru
Re: Orbi RBK50 Firewall Blocking ESET Antivirus Updates
Orbi doesn't block security progrems or update processes for app or other devices.
Message 2 of 7
CrimpOn
Guru
By chance is Bitdefender Armor activated on this Orbi?
Message 3 of 7
DK62
I just checked and my firmware is the latest version. I'm pretty sure my modem isn't the issue. However, I do use OpenDNS. I wonder if that would be the problem.
Message 4 of 7
DK62
No. I learned my lesson on that back in December and contacted Bitdefender's tech support to delete my account.
Message 5 of 7
Guru
What happens if you use default DNS seen or detected by the RBR?
Modem mfr and model is helpful. We are just checking for any router and wifi here is all. Helps us determine this as this can cause problems if present.
Message 6 of 7
CrimpOn
Guru
Aha!  Something easy to test.  Change the DNS entries to Google (8.8.8.8 and 8.8.4.4).  If OpenDNS is the culprit, you will know almost instantly!
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1037 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
