Reply
Orbi RBK50 vs RBR50 Difference
BruDaniell
I found the RBR50 selling the two piece set for $269, which is about $100 less than the RBK50 two piece system which makes me suspect there must be a significant difference.  Cannot find an article explaining what the difference might be.
Message 1 of 3
Accepted Solutions
AmitR
NETGEAR Employee Retired
Re: Orbi RBK50 vs RBR50 Difference
Correct.  You will not be able to pair two Orbi Routers together to form a system.  You need 1 Orbi Router + (1 or more) Satellites.  We do sell Stand Alone Orbi Routers and Stand Alone Satellites
Message 3 of 3
All Replies
loomis1975
Luminary
RBK50 is a kit, one RBR50 Router and one RBS50 Satellite.
RBR50 is just the Router designation, so if its two pieces of RBR50 you are getting two routers.  Not very useful together.
Message 2 of 3
AmitR
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 29024 views
  • 4 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
