- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK53 with Vodafone Modem and Firewall query?
- Mark as New
- Bookmark
- Subscribe
- Permalink
A quick query. I have my Vodafone modem/router with wifi turned off and connected to the Orbi base unit. Everything works well. My question is regarding the Firewall status of the Vodafone modem. Should I leave it turned off or on? Does it make a difference at all? Either way, my system works absolutely fine, but it would be nice to know if leaving the modem firewall switched on or off is the recommended option? Many thanks in advance for any help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK53 with Vodafone Modem and Firewall query?
There is a built in firewall on RBR so having one in front of the RBR is redundent.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You can try option #2 if your modem can't be fully bridged...
