- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBR50 Frequently disconnecting/reconnecting to the Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recently (February) bought the Orbi RBR50 from Costco to replace a rather expensive gaming router that needed to be power cycled every few days because it could not keep up with all the smart-home devices we have around the house.
It seemed to work great, but my wife kept saying she was having problems with work-from-home VPN connection. It would disconnect and connect again 20-30 seconds later.
Now that I am working from home, I am having similar problems. I will be typing on my remote desktop when, without any notice, no text would be entered. A few seconds later I will see the "disconnect, trying to connect 1 of 20" message appear. I usually reconnect in 10-15 seconds. Usually.
I have the Orbi connected to the Verizon Gigabit router. I am using its address as the DNS. Looking at the logs, there is a general error that appears to have something to do with transferring info to the "slaves":
Jun 6 17:16:51 202
0named[1430
]err<139>
zone 1.168.192.in-addr.arpa/IN/internal-clients: zone serial (2008122601) unchanged. zone may fail to transfer to slaves.
I have turned off the WFi to the FiOS router, so it is not a conflict with that, and the Orbi is set to be in AP mode. I have tried my machine directly connected to the Orbi and to the FiOS router (CAT5) and get the same problem.
The only thing I have not tried is turning off the Orbi and running directly from the Verizon router.
Has anyone else had similar? Any solutions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBR50 Frequently disconnecting/reconnecting to the Internet
YES! I have th exact same problem. Our TV and Apple TV have pop ups that show each time internet was dropped. It happens multiple times per day and comes back quickly. But using apps like Sling and HBO Max, we get booted out and have to restart our program each time. It's SO frustrating.
Also connected to Verizon Fios router with its WiFi signals turned off. Orbi in AP Mode. Happens either via WiFi or wired connection to Orbi satellites. RBR40 Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
@mhbethany wrote:YES! I have th exact same problem. Our TV and Apple TV have pop ups that show each time internet was dropped. It happens multiple times per day and comes back quickly. But using apps like Sling and HBO Max, we get booted out and have to restart our program each time. It's SO frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update.
I tried with just the Verizon Router, worked fine.
What I did last was use my old setup. I do not have it as AP, I have it setting up its own IP address chain and then connecting to the Verizon router. It does not drop anymore, but there is a down side.
I have the Net Server hooked to the Orbi. Works great if you hard wire to the Orbi or use one of its wireless signals. You CAN'T connect to it if you wire or link to the Verizon router.
Same exact problem I had last time with my previous router.
I was hoping I did not have this problem again, but back to the start.
(I am guessing it is an IP assignment glitch that causes a conflict. NONE of the remote items have been having a problem with this since I went back to the old setup...)
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the ISP modem/ONT already has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
You can try option #2 first and see if this helps any.
@Ninjahedge wrote:Update.
