packavette's avatar
packavette
Orbi RBR50 poor video call quality
Hi,
I have had the RBR50/RBS50 combination for a few years, and over the past few months have noticed an issue as we are working from home more and making more video calls.  When I have both the router and satellite turned on, my internet seems to work fine for simple web browsing, streaming Netflix, etc.; however, when we try to use Facetime or any other type of video chat we are unable to hear the other person clearly, and they have trouble hearing us as well.  If we unplug the satellite, the quality of video chats drastically improves, however the range throughout our home is more limited.
Are there any setting I can check that may be the cause of this?  Through the Orbi app, I have verified we have the latest updates.  The router is on the 2nd floor, and satellite on 1st floor (3200 sq ft home).  Speedtest through the app shows 432 Mbps download, 23.4 Mbps upload.
Thanks for any suggestions!
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    what are you using to access Facetime?  Tried different platforms and/or software?
    • packavette's avatar
      packavette
      Yes, this occurs on a work provided computer using Teams and Zoom, a personal computer using Google Duo, and several iPhones using Facetime.
      • CrimpOn's avatar
        CrimpOn
        Everything connected over WiFi, or some wired?
  • CrimpOn's avatar
    CrimpOn
    This is double my download/upload speeds.  Facetime and Zoom perform normally.
    Perhaps it would be worth a brief experiment to check Speedtest using the WiFi device (iPad?) from the same location.
    When we Facetime relatives, both video and audio are sensitive to location and sometimes sensitive to the orientation of the tablet.
