Reply
Highlighted
Orbi RBS50 Backhaul, is it possible to confirm if my Satellites are using the ethernet backhaul?
When I look at connected devices, both satellites are displaying connected 5ghz, I would expect this to have changed to wired the same as the other devices.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 5
Highlighted
Master
Re: Orbi RBS50 Backhaul, is it possible to confirm if my Satellites are using the ethernet backhaul?
If you wired your satellites with the router and you still see the connection type as 5 GHz then there must be something wrong with the cables or something else.
Both the web GUI and the Orbi app should show you the satellites as wired if they are wired.
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208Time Zone CET (Sweden)
Message 2 of 5
Highlighted
Guru
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch in the configuration?
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK50 v2.7.0.70(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 3 of 5
Highlighted
Router Firmware Version V2.3.5.30
I'm actually connecting the router to a Meraki Switch, which then  goes into a Palo Alto VM300 firewall before reaching my ISP router.
AP Mode as I have the VM300 firewall handling all of my security and routing.
The satellite is just connected to a dumb NG switch, through a patch panel which runs to my downstairs
Message 4 of 5
Highlighted
Guru
What is the Mfr and model# of the ethernet switch in the configuration? Reason for asking is that some switches can cause problems with Orbi satellites being connected via ethernet. Particularly managed or green ethernet featured switches.
Best way to confirm the RBS is connected via ethernet is to check the status on the RBR connected devices web page. The RBS will either show wireless or wired.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 441 views
  • 0 kudos
  • 3 in conversation
Announcements
