rce3's avatar
rce3
Guide
Jul 24, 2017
Orbi STP/BPDU errors
Hi - looking for some information about how Orbi uses the STP/BPDU protocols.  Can't find any via google, so hoping that someone here knows more.
I am using an Orbi RBK50 in AP mode plugged into a Ubiquiti EdgeSwitch.  The Edgeswitch is reporting a BPDU error from the Orbi as below:
Jul 24 04:47:44Errordot1sBpduReceive(): Discarding the BPDU, since it is an invalid BPDU type
Jul 24 04:47:44Noticedot1sBpduReceive(): Invalid Forward Delay
Jul 24 04:47:42Errordot1sBpduReceive(): Discarding the BPDU, since it is an invalid BPDU type
Jul 24 04:47:42Notice
It's been suggested to me on the Ubiquiti forums that I need to either change/disable the STP mode on the Orbi or adjust the "Forward Delay".  However, I can find no ability to do so in the Orbi UI.
Questions:
1.  Is there any ability to adjust or disable the STP/BPDU settings on the Orbi?
2.  What are the default settings for the STP/BPDU protocols on the Orbi?
Thanks.
-Robert
  • I don't have your answer, but I do have an RBR50 in AP mode plugged into a Ubiquiti US-8-150W switch. This is similar to the Edgeswitch. No STP issues with that, that I am aware of anyway.
    Are you certain it's the Orbi causing the errors?
    Also, what exactly do you have plugged into the switch.  RBK50 is the part number for the kit. Is it the the router or the satellite that's plugged into the switch?
    • rce3's avatar
      rce3
      Guide
      It's the router that's plugged in to the Edgeswitch, though again operating in AP mode.  I believe it is the Orbi router that is causing the problem as the error messages stop when I unplug the router and resume immediately when I replug the router.
      I've not plugged the satellites in yet, so can''t comment on whether they also generate this error.
      I know that the Ubiquiti Unifi switches are slightly different than the Ubiquiti EdgeMax switches, but I'm not familiar with the details.  My system is working, in the sense that wireless devices can connect via the Orbi Router and work fine.  It's only when I inspect the system logs on the EdgeSwitch that I notice this error.  When you say your system has no issues, have you looked at the system log?
      Thanks!
      -Robert
      • st_shaw's avatar
        st_shaw
        Master
        Thanks for the further detail.
        I expect that plugging-in the satellites would cause issues, such as a network loop. That's why I asked.
        I looked at the "Events" in the Unifi controller and don't see any errors noted there.  I'll need to SSH into the switch to see if there is a log there analagous to the Edgeswitch.  There's no GUI on the Unifi switches.
