jasonlathrop's avatar
jasonlathrop
Initiate
Nov 12, 2019
Orbi and Apple TV Gen 4
I have an Apple TV 4th Gen reporting excellent signal strength and not that far from my Orbi Router.
SpeedTest.Net reports decent speeds, 30-40mbs, 12 ms ping, most of the time.
But, about 3-10 minutes into a streaming session, the streaming chokes. I checked SpeedTest again and the throughput has dropped to a few kbps--basically stopped.
It is mostly predictable but not consistent. Turn on AppleTV, check speeds, checks signal strength--try to watch show--throughput plummets.
Orbi Router is in AP mode on a CenturyLink fiber modem with 1GB nominal service.
All my other devices get excellent bandwidth in various locations both closer and further than the AppleTV.
It is obviously either an Apple bug or an Orbi bug. Anybody have any thoughts?
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Do you have Circle or Armor enabled?
    If you are running out of things to try, give these settings a shot.
    - Preamble Mode: Short Preamble
    - Disable Fast Roaming
    Apply the changes and then reboot the Orbi router/Satellites and wait for the Satellites to fully sync with the router by going to Firmware Update page to verify that the Satellites are not stuck in "Waiting for connection".
