LSweet's avatar
LSweet
Orbi or Nighthawk A7000 Massive Ping Spikes
This has started to get much worse recently but for a long I would experience lag spikes that would last about 3 seconds. These lag spikes would happen about every 20-30 seconds. I would ping google in my CMD and everytime I noticed one of these lag spikes ingame, I would check the CMD and notice that my ping went from around 20-30 to 2000-3000 or it would even say "Request timed out." Now I still do not know if it is my network adapter, Nighthawk AC1900 since I have of them causing ping spikes, or my Orbi routers because I seem to get the problem worse when connected to them than when I am at my other house connected to a simple Asus router. The thing is, I experienced them on both routers, which led me to think it was the AC1900 Adapter while when I connect to the Orbis, as just mentioned, it happens much much more frequently. One thing I noticed is that it does not happen when I connect my Laptop to the wifi, tho it does get lag spikes about the same times, they are only about 40ms. If anyone has had similar problems with the AC1900 or the Orbi mesh system, I would truly appreciate some help. Thank you.
  • If pings are good when closer with the PC wirelessly and good with wired directly to the RBR, then I would presume your adapter maybe the cause if what your seeing.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    So this happens wtih out the wifi adapter being online?
    How is your test pc connected to the RBR? wired or wireless?
    • LSweet's avatar
      LSweet
      I have the latest firmware for both the router and my single satelite.
      My orbi is operating in Router Mode.
      My Router and Satelite and about 30 ft apart.
      I use auto channels for 2.4 Ghz but I set my 5 Ghz to 36 because it was the best and most open.
      I do have neighbors around with wifi but they run on different channels.
      I just disabled BEAMFORMING just to see if it helps but I do have WMM and MIMO enabled.
      I have Daisy Chain, Fast Roaming, and IPv6 disabled.
      My test PC is my laptop and it has its own built in wireless adapter but it doesn't seem to have any problems.
      I have not tried to set up my main with with Ethernet but I tried another network adapter and after like 2 minutes the thing stayed "Request timed out" when I pinged google. Its like it also lag spiked but never recover. Another thing I have noticed is the lagspikes seem to go away for about 30 minutes after I restart my router.
      • FURRYe38's avatar
        Do this, Turn OFF the RBS and disconnect the RBR from the ISP modem/ONT. Ping the RBRs IP address 192.168.1.1...Use a wired connection first, then try wireless.
