- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Port Forwarding not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello. Recently I wanted to open a dedicated server for csgo, which port is 27015. But it doesn't works, I tried to make a port test and this happened. Any solution? (That's weird because I have the port opened and uPnP unabled)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Port Forwarding not working
Have you checked that 10.0.0.2 responds as expected on 27015 from the internal network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep, I executed netstat -an and it doesn't appear 10.0.0.2:27015.
Also, I did a port test on whatsmyip and it shows me this
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is 10.0.0.2 the computer running the service or your router? If the latter, you need to forward it to the IP address of the computer where the required service is running instead.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yup, 10.0.0.2 is the computer's internal IP adress
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The modem is a ZTE zxhn f660 and yes, is connected to NG router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's what I did. I contacted my ISP to configure the modem into transparent bridge mode and I have the same problem with the ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is uPnP disabled on the Orbi if you configured any Port Forward configurations?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
And you do have a device using the port while your checking to see if it's working correct? You need to be accessing the port before checking it's status.
What is the IP address the Orbi router is getting from the ISP modem? ##.##.###.### or is it something different like 192 or 10 or 172? Just checking to ensure the modem is fully bridged.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the Orbi is in AP mode Then you shouldn't have a problem.
Seems like this is a NAT issue.
Can you try putting the ISP Modem back to router mode and connect your PC there and see if Port fowarding works there?
THen try connecting the Orbi in AP mode to the ISP modem in router mode and try your remote devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
