C0lin
Apr 28, 2020Follower
QOS RBR50 error
I have the orbi RBR50 and want to set up the QOS for gaming but when I go and add a new priority rule it always gives me "400 Bad Request: This server does not support the operation requested by your client." Is there any way to fix this issue. Thank You in advanced.
C0lin wrote:I have the orbi RBR50 and want to set up the QOS for gaming but when I go and add a new priority rule it always gives me "400 Bad Request: This server does not support the operation requested by your client." Is there any way to fix this issue. Thank You in advance.
How are you tryiing to make a QoS setting? My RBR50 Orbi web interface has no menu selection for "QoS".
What firmware release is on this Orbi?
QoS is automatic on Orbi. You can't make any changes.
C0lin wrote:I have the orbi RBR50 and want to set up the QOS for gaming but when I go and add a new priority rule it always gives me "400 Bad Request: This server does not support the operation requested by your client." Is there any way to fix this issue. Thank You in advanced.
