xiiaobai92's avatar
xiiaobai92
Query on speed difference using OOKLA
Hi,
I had recently did a speed test using the OOKLA speed test on my android phone and found that there are quite a big difference between the speed using the OOKLA speed test app and the built-in OOKLA speed test in the ORBI app. I would like to ask why are there difference in the speed when I had tested both at a same place and how could I increase the speed other than standing right in-front of the router as I had already done so.
OOKLA Speedtest APP:
Download speed: 351 Mbps, Upload speed: 206 Mbps
ORBI App by OOKLA Speedtest:
Download speed: 489.29 Mbps, Upload speed: 789 Mbps
  • You will see differences when using a wireless device to test it.
    DarrenM
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    DarrenM
