bfish2534
Jul 01, 2020Follower
RB20 Speed Test
I have and RBR20 and one RBS20 satellite. We have been having a ton of issues with our speed slowing way down throughout the day (video's lagging, web pages slow to load, wifi calls dropping, etc). I do a speed test on the Orbi App and I always get good results (150 mbps down and up). However, if I run a speed test on the internet, it says I am getting only 1.5 to 6 Mbps down and up. Can someone tell me what is going on. For service, I have fiber through Frontier with their leased modem. All firmware is updated and I have tried all the fixes from other threads on here.
1 Reply
Has a factory reset and setup from scratch been performed since last update?
What is the Mfr and model# of the ISP modem the NG router is connected too?Any Wifi Neighbors near by? If so, how many?
