Orbi WiFi 7 RBE973
Reply
RBR 10
venksiva63
RBR 10
RBR 10 - 4 satellites
have gigabit internet from my provider (Century Link), and the Orbi app tells me that the speed is 700+ Mbps download and 850+ Mbps upload, which some research has told me is measuring speeds at the router. When I run the Speedtest app on my phone or laptop, though, while sitting a few feet from the main Orbi router, I'm only getting 20-50 Mbps for both download and upload. Is there some way to troubleshoot why the speed on WiFi is very low ?
I have tried to contact support many times and tried all the options to increase speeds.I just want to try one last chance before i toss this Product and go to something else.
Thanks in advance.
Venkata
Message 1 of 5
Guru
Re: RBR 10
Are you testing over 2.4ghz or 5ghz?
The orbi devices do bandsteering and can move devices between 2.4ghz and 5ghz.
2.4ghz is much much slower than 5ghz.
Also, just an fyi, the RBR10's aren't going to hit gigabit speeds over wireless. The primary router can do it over a hardwired connection but wouldn't hit it over wireless.
Message 2 of 5
venksiva63
Re: RBR 10
Are you testing over 2.4ghz or 5ghz?  5 GHZ
2.4ghz is much much slower than 5ghz.  I dont know what this means
Also, just an fyi, the RBR10's aren't going to hit gigabit speeds over wireless. The primary router can do it over a hardwired connection but wouldn't hit it over wireless. Its fine i dont need Gigabit i just need a decent speed like atleat 200-300 speeds.
Message 3 of 5
Guru
Re: RBR 10
Your sure your device is connected to 5gh?
What device are you testing on?
A device with only a 1x1 antenna isn't going to have the same speed as a 2x2 device.
Message 4 of 5
Mikey94025
Hero
Re: RBR 10
Try following the steps in the Community FAQ: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-... See if the slow speeds start from the RBR and also if wired devices are affected as well as wireless devices.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1722 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
