- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
[RBR40] Port Forwarding not working for Port 80
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Evening,
I have a Orbi Mesh Router with 2 satellites in my house.
In my network I have multiple servers, one of them being a webserver.
To enable public access I enabled port 80 in PORTFOWARDING to the servers IP address.
When trying to connect internally to the server I get the expected website displayed. However when trying
externally it will not connect.
Couole of things I made sure:
- The domain name points to the correct IP address (my Modem).
- Portforwarding points to the right internal IP address
- Server is listening to the correct PORT 80
- UPNP is switched off
THings I tried:
- I let my webserver listen to port 81
- put a port forwarding rule in for port 81
This works. So port 81 is reachable externally. But not when trying port 80.
Any ideas whats going on or what I could try?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: [RBR40] Port Forwarding not working for Port 80
@pipechess wrote:This works. So port 81 is reachable externally. But not when trying port 80.
I am unable to reproduce the problem. I forwarded port 80 to my Pi-hole web portal. Disconnected from Orbi to use mobile LTE connection. Opened http://<my public IP address>/admin/ and up came the Pi-hole interface.
I did not select from the drop down menu of services (starting with FTP at the top. HTTP is the second one.) and instead created a custom rule using port 80. I doubt Netgear would have included HTTP on the list of services and not allow forwarding port 80.
Since port 81 forwarded correctly for you, it is pretty clear that there is not a router in front of the Orbi.
I have no clue why it didn't work for you. Certainly does for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah,
the odd thing is that this worked a couple months ago.
I don't know if this is a firmware bug after the latest update and/or if the router now reserves port 80 for internal puposes?
This is driving me nuts. My entire server infrstructure is down because of this.....
- Mark as New
- Bookmark
- Subscribe
- Permalink
@pipechess wrote:the odd thing is that this worked a couple months ago.
My Orbi firmware is v2.7.2.104. Port 80 on the LAN side is used for the Orbi web interface, but that is entirely separate from forwarding port 80 from the WAN side to a specific device. The LAN side can any any number of devices listening on port 80. (I have 2 Pi-holes which are listening on a total of 4 interfaces.)
Did you try forwarding using both the pre-defined (drop down menu) HTTP port and defining a custom rule for port 80 TCP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please check your private messages.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried the custom rule and the predefined one. Difference is just that the pre-defined rule only uses TCP instead of TCP/UDP.
Odd thing is that port 443 forwards just fine. Just not port 80.
Here is my IP in case you are interested: 68.109.118.221
Try port 443 and port 80 via a port checker or traceroute.... In traceroute port 80 just dies at the router
I also reverted back to a previous version and factory rese4t the entire router. No luck.
Also attached a screenshot from my PF
- Mark as New
- Bookmark
- Subscribe
- Permalink
https (port 443) did not work for me to that IP (68.109.118.221)
This is for sure the public IP address?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anyone get to the bottom of this?im having the same problem. port 80 will not work
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
> Yes. It was my ISP. They started blocking inbound port 80.
For the usual problems with port forwarding, see:
https://community.netgear.com/t5/x/x/m-p/1859106
If you can access the server from the LAN using the router's
WAN/Internet IP address, then the router would seem to be doing its job.
If actual outside-world access still fails, then I'd blame the ISP. Or,
at least, something on the ISP side of the router.
Revealing the identity of such ISPs might help future readers.
