Larkum's avatar
Larkum
Follower
Sep 26, 2019
RBR50 Disconnecting devices at 02:45 am daily
Hay, So this is more of a discussions starter then an issue as I have resolved it now, but wanted to know if anyone knows why it happened and also to maybe help others out.
A few days ago I found an issue on my home network, My home server (Used to host games) was going offline between 02:45 and 05:50, I spent days trying to find the answer, spending hours trawling through logs on my server and router, but found nothing. about 2 days in I found that a few other devices where all going off line at the same time, with exception to 1 device that was going offline 15 minutes before, that device was a Sky Q 2Tb TV box going offline at 2:30 and reconnecting at 5:50.
So after a bit of investigation I found that it would enter 'Eco mode', a sort of Hibernation mode to reduce power usage set at a time when most people are asleep, so naturally I turned that off and all is fine now.
But shortly after (Within the hour) I found that my Orbi Router had a firmware update outstanding, I thought it was strange as I had implemented that about a week ago I had thought, it turned out that the update had only been applied to one of my satellites, so I ran the update to the router and the remaining satellite.
Role onto this morning sat at work waiting for my server to go down, think what can I try next, nothing issue seems to have been resloved.
Moving on I am now at a loss, was the issue caused by the Sky Q box or was it due to the firmware not allowed?
1 Reply
  • FURRYe38's avatar
    Have you manually downloaded the Orbi FW files and installed them directly using a wired PC and web browser?
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
