- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
RBS 50 shows blue then goes magenta
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: RBS 50 shows blue then goes magenta
Possible the FW on the RBS is not using the same version as whats on the RBR which they both need to be using same version FW.
What you need to do is factory reset the RBS. Wire connect a PC to the satellite. Already have the same FW version RBS file downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I tried an ethernet cord which ays unidentified network and I try to connect to that and it says network unreachable as well.
What am I doing wrong?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@yankees177 wrote:
Hey so just tried. I can connect via WiFi to the satellite but when I go it it says https://192.168.1.250 network unreachable and it doesn't give itself an IP address.
What WiFi name allows you to connect to the RBS50 after it has been factory reset?
When connected to the satellite with an ethernet cable, can you open a web browser to http://192.168.1.250?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes, please try wired connection. Wireless probably doesn't work for this method,
