Orbi WiFi 7 RBE973
Reply
RBS40v on fw 2.3.6.4
Toff14
Follower
Orbi Satellite (RBS40V) connection seems to drop and ring turns to magenta occassionally (about once a day). Connection is fine once it is restarted but seems odd to require a restart almost everyday.
Satellite is connected to router via ethernet backhaul, hence can't be distance issue.
Noticed that this started happening after fw upgrade to 2.3.6.4 for satellite and 2.5.1.18 for RBR50.
Anyone else encountered this and any suggested fix.
Model: RBS40V|Orbi Voice Add-on WiFi Satellite and Smart Speaker
Message 1 of 3
Accepted Solutions
Guru
Re: RBS40v on fw 2.3.6.4
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only by un-checking the check box. Save settings and reboot the router and satellite(s).
Has a factory reset and setup from scratch been performed since last update?
Message 2 of 3
All Replies
Guru
Message 2 of 3
Guru
Any progress on this?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 518 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
