nickolausj
Aug 13, 2020Aspirant
Satellite internet drops out or slows randomly
I am currently on 2.4.1.16 and have a router w/ single sat system. Now I am having an issue with the satilite randomly dropping connectivity to devices to almost no bandwidth.
The satilite is currently 25-30 feet away from the router. I have moved it to 15' away to 45' away... 45' away caused it to loose it connection to the router itself... 15' makes no difference, I get the same odd bandwidth drop.
Any ideas?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Has a factory reset and setup from scratch been performed since last FW update?- nickolausjAspirant
Yes, I recently factory reset it and I disabled UPnP, Daisy Chaining. I enabled beamforming. It's still dropping out. I have a lot of HUE lights, and sonos speakers, and nest security/cameras.
It is still dropping out randomly.- FURRYe38Guru - Experienced User
If you turn off the RBS, leaving the RBR online, does the devices maintain connections with the RBR?
Possible your RBS maybe faulty...
