- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Satellites and wall plug in
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would like to know if it’s possible to connect 3 satellites and also add a wall plug-in to my router, I’ve heard that only 3 satellites per router are allowed.
Thanks a lot in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Satellites and wall plug in
Users on this forum have reported up to six satellites on one Orbi system. If my memory is correct, I believe the technique is to power off an existing satellite, add the new one, and then power up the existing satellite. Now, "there are four!" To add a fifth, power down two, add one, power up those two. Now, "there are five!"
I have not done this myself. Alas, my palatial home is "overserved' with one RBR50 and one RBS50.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the AC2200 Orbi Router and satellite installed, want to add an additional satellite...when I added the 2nd..my wifi speed slowed down to near nothing....without the additional satellite, my wifi speed is d/load 225 and upload is @ 11. What could cause the downgrade in speed with additional satellite?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
FW versions same across RBR and RBSs?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
What was the reason for adding a 2nd RBS?
@imalckydog wrote:I have the AC2200 Orbi Router and satellite installed, want to add an additional satellite...when I added the 2nd..my wifi speed slowed down to near nothing....without the additional satellite, my wifi speed is d/load 225 and upload is @ 11. What could cause the downgrade in speed with additional satellite?
Thanks
