MelsPartner
Jan 12, 2021Initiate
Set up 2 routers 1 modem
How to set up 2 routers with one modem
Ok so I know nothing.
I've got a modem/router supplied by my ISP.
This is in an outhouse building (why the designed it like that i don't know
From this place in one direction I have a wire going to the main home and a router there.
In the opposite direction we have now built an office in the garden for me to work from and I have a router there.
My question is how should I set this up correctly.
Do I need to stop the router combined modem from being a router?
Can I continue to have both routers connected direct to the modem?
Help because what is happening at the moment isn't working. We are getting alot of Internet dropping.
One router is a rbk30 the other rbk50
Thanks in advance.
Thanks in advance.
Firstly, you should disable the router portion of your cable modem. Otherwise you'll have two "NAT"'s, which can cause complications.
How-to-fix-issues-with-Double-NAT
One can use 2 routers but it is unneccessarily complicated. There is a brief description at
Option 2 is the way to go, with using the 2nd Orbi as an access point (in other words, disabling its router functions). A better way (that will allow roaming between the different parts of your house) is to use a single Orbi router and as many Orbi satellite as needed to provide a single WiFi name (SSID) throughout your house.
- vajimMaster
Set up 2 routers 1 modem......................WHY?
- alokeprasadMentor
- MelsPartnerInitiateThank you this very helpful
You could have two routers connected to the modem thought it would not be a ideal configuration.
Thanks in advance.- vajimMaster
Message 3 pretty much sums it up.
