- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Skybell HD and Netgear Orbi – synced but no video
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Just had my SkyBellHD installed. I’ve synced and connected to my wifi. I’m running a netgear orbi (router + 2 satelites). The skybell connects to one of the satelites and the speed test is >40mb/s. I get notifications when there is motion or pressed but i get no video (just the spinning wheel) and no activity log. I’ve tried to trouble shooting but no success. Any advice? Is it a known issue that orbi and skybell dont work well?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Skybell HD and Netgear Orbi – synced but no video
If you already unticked this option to disable it, please ignore. Otherwise, give this a shot.
- Disable 20/40 MHz Coexistence
- Mark as New
- Bookmark
- Subscribe
- Permalink
@clibba wrote:
Hi
One of the reasons that can cause this issue is having double NAT in your network. If your ISP modem is acting as a router and does NATing on the incoming WAN traffic then this can cause different issues since Orbi is also doing NATing. You need to check if you have double NAT.
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8 (traceroute to Google’s DNS server)
- If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
- If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the root cause of the issue,
- Mark as New
- Bookmark
- Subscribe
- Permalink
I get "command not found" when i run this in my mac's terminal application. What am i doing wrong?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@clibba wrote:
... I get notifications when there is motion or pressed but i get no video (just the spinning wheel) and no activity log...
Is this client connected to same Orbi WiFi or it's connect to LTE for example?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try downgrading to 2.2.1.212 to be sure that it is not a probelm with the newer code. My SkybellHD could not join on the new code for some reason. Worked fine before the upgrade, and worked fine again when I downgraded.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m on hfc broadband. The supplied isp broadband terminal box that connects to my orbi is arris cm8200
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you ever get a fix for this? My Skybell HD will randomly work to view live feed one minute and the next I'll just see a "loading circle". When it stops working it'll stop for a few hours.
