dirceuguerra
Jun 02, 2019Aspirant
Speedtest via router x speedtest via app
Hello. I’m using an Orbi RBR-50 + RBS-50 + 2 RBS-40. The satellites are all connected via gigabit ethernet on the RBR-50.
Orbi is working as router mode and all of them updated to the latest firmwares.
I used to work in AP mode. And everytime I used to do speedtest in orbi’s app, i got the real speed performance contracted.
Since I’ve changed Orbi’s to work in router mode, most of this in app speedtest shows a slow speed in up and downloads. Almost 10x slower.
The strangest thing is, if I do the test in my wired macbook, it shows the real speed. In speedtest app over IOS, the same. I’m only getting strange results over Orbi’s in app speedtest.
- ekhalilMasterVery strange! Have you tried rebooting the Orbi Router? You can also try renewing the DHCP lease by going to (in the web GUI) >> ADVANCED >> ADVANCED Home >> CONNECTION STATUS >> RENEW
What FW is currently loaded?
The strangest thing is, if I do the test in my wired macbook, it shows the real speed. In speedtest app over IOS, the same. I’m only getting strange results over Orbi’s in app speedtest.- dirceuguerraAspirantIt’a a Sagemcom F@st 5655 v2. I live in Brazil and my internet provider is Tim Live fiber with 300mb download and 180 upload.
All Orbi’s uses the latest firmware. RBR 50 and RBS 50 uses 2.3.1.60. The two RBS 40 satellites uses 2.3.1.58.
A strange thing I noticed today bur haven’t gone too deep yet is that a speedtest using Ookla app when my iPhone is connected in Orbi’s router shows the same low up/down speed that Orbi’s in app speedtest.
When I’m connected over any of the satellites, i have full speed (300dw/180up) on ookla’s app.
It seems the problem is restricted to the RBR-50 unit.- ekhalilMasterDo you happen to have WAN Port mirror to LAN port1 enabled in the Router’s debug page?
