Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2020-12-01
08:57 AM
2020-12-01
08:57 AM
Struggle setting up Orbi RBK13
Recently, bought a used Orbi RBK13 from ebay, followed all the steps right but somehow I am not able to login to the wifi named 'ORBI00'
I resetted the orbi router, the setup says I am supposed to get wifi called 'Orbi_setup'
I am unaware of the password.. also tried copying password from the orbi app ... even that dont work
The light on the router is solid blue
Any help would be much appreciated... thanks guys
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2020-12-01
09:37 AM
2020-12-01
09:37 AM
Re: Struggle setting up Orbi RBK13
So try pressing the reset button for 15 seconds then release. Connect a wired PC to the RBR and walk thru the setup wizard at 192.168.1.1 or orbilogin.com with a web browser...
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.17.12
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2020-12-01
09:49 AM
2020-12-01
09:49 AM
Try connecting a pc/laptop to the lan port. disable the wifi on the device you connect to it. Then attempt setup. This tends to go the smoothest for setup.
Also, when many reset, the just click the reset button. It needs to be pushed and held for 7-15 seconds while powered on.
Find manuals, guides, firmware here:
https://www.netgear.com/support/product/rbr10
CM2000-> RAX200-> GS716v2-> EX8000
Message 3 of 3
