- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Telephone Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I purchased and installed the Orbi to take the place of the cox panoramic wifi modem but I missed the fact that our home telephone was also plugged into the cox wifi modem. I really like the Orbi but it doesn't support plugging in a phone. Does anyone have a solution or a work around? I am willing to purchase an additional modem for the phone if necessary.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Telephone Connection
Did you have the CBR40 or a RBR series?
The CBR system doesn't support phone lines. NGs CM1150v does.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the CBR40 which I really like. Is there something I can add just for the phone?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unfortunately no. Thats hardware feature which the CBR40 doesn't support.
If you need phone line support, you can do the following configuration:
CM1150v and then attach a RBK40 system to the CM modem. RBK40 or RBK20 series is same as the CBK40, just no built in modem in the RBK series.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have our phone line hook to a Verizon wireless home phone connect that has worked pretty welll. I would suggest you keep the home phone connect away from the orbi though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi system doesn't support any phone line support. The CM1150v cable modem does.
@Tjharris6 wrote:We have our phone line hook to a Verizon wireless home phone connect that has worked pretty welll. I would suggest you keep the home phone connect away from the orbi though.
