- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
TreeHue Christmas lights
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just purchased TreeHue christmas tree lights and they will not connect to my network. I tried them at a friends that uses Google Mesh and it connected. This is how I know the device works. It will only connect to 2.4GHz but I am set to automatic and I have 3 other device connect to 2.4. Please help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: TreeHue Christmas lights
What FW is currently loaded?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Try channel 10 as well. Try setting WPA security to WPA, then try WPA2 and AES only. As a quick test, disable WPA security on the Orbi and see if it will connect, then re-enable WPA security.
MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. So try this out as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We’d greatly appreciate hearing your feedback letting us know if the information FURRYe38 provided has helped resolve your issue or if you need further assistance.
Blanca
Community Team
