JCar
Jun 03, 2021Aspirant
Used Orbi transfer ownership
I purchased an AC3000 second hand. The previous owner said they forgot their netgear login info I would need to reach out to support. The satellite is registered to me.
How do I gain registration on the router? I have gotten zero response from netgear support.
You don't need to register it to use it.
Start by factory resetting it back to stock.
Push and hold reset for 7-15 seconds while its powered on.
That'll get it to the defaults.
then you can install it and use it as normal.
https://kb.netgear.com/1160/NETGEAR-Product-Registration-FAQ
No.
Just do a factory reset and reinstall and you should be good.
