Jagdriver's avatar
Mar 29, 2017
VPN and DDNS?
I want to set up a VPN on my Orbi Wi-Fi router. It requires tghat I enabale DDNS. When I go to do that, I'm informed that I need to provide a User Name and Password and that "Your connection to this site is not private."
Why do I want to offer up my Orbi admin password to some unknown dialog box informing me that my connection isn't private?
  • schumaku's avatar
    schumaku
    Newer browser versions (ie. Chrome and Firefox) put up warnings - either along with the input field, or as part of the URL on top of the browser - of a connection to a device is insecure. Insecure means its' not https with a valid certificate, matching the URL used.
    • Jagdriver's avatar
      Jagdriver
      Tutor
      Thanks.
      Why do I need to use DDNS to set up a VPN on my Orbi?
      • st_shaw's avatar
        st_shaw
        Master
        Strictly speaking, you do not need DDNS to use VPN.  You could connect to your router using your WAN IP address, if you knew it.  However, the WAN IP could be hard to remember.  Plus, most home routers are issued a dynamic WAN IP via DHCP, and the address could change without your knowledge. So, DDNS is often used to map a domain name, like jagdriver.com, to your dynamically changing WAN IP address.
